How to reset admin password on F5 BIG IP LTM 2000 v11.2.1?
I need help to reset the admin password in our F5 LTM, since I cannot login the default password anymore (weird).
Anybody can help me to do the step by step guide on how to do it?
  1. Start the system in single-user mode.
  2. Type the following commands:
    mount -a
      passwd root
  3. When prompted, enter a new password.
  4. Type exit or reboot to return to the normal operating mode.
Restarting the BIG-IP system in single-user mode 404 Page not found | BIG-IP Documentation
Do you know the root password? If not then you’ll need to reset as per Vitaliy’s instructions first.
If you do know the root password or you’ve reset it, then to reset the admin password you need to have an SSH / Console session. Login as root and type in
tmsh modify auth user admin prompt-for-password
, it will then prompt you for a new password and then you will need to save this
tmsh save sys config
Hope this helps,
N
I’m having issues following the instruction in starting the system in single-user mode. Can you provide me a simple step by step guide?
Do you use this soulution 404 Page not found | BIG-IP Documentation
Hi Nathan,
Im done changing the root password via single user mode using grub97. I also successfully changed the admin password in tsmh.
thanks a lot!
Yes I have followed that link. I just used the command passwd root and I didn’t use the mount -a. What is the importance of this command mount -a ?
Good news w
mount -a : mount all stuff from /etc/fstab
If I dont use the mount -a, is there any issues?
Hi Vitaliy, Thanks also for the help and info.
