How to replace the hostname from a FQDN in HTTP:HOST
Hi
How is it possible to replace only the hostname within an irule?
Example:
Client requests www.trustme.com so [HTTP:Host] contains this name.
How can I replace only the “www” with “www2” and response
www2.trustme.com to the client?
Many thanx
bb
     if { [string tolower [HTTP::host]] eq "www.trustme.com" } {
          HTTP::redirect "http://www2.trustme.com[HTTP::uri]" } }
That’ll send a redirect to the client for www2.
Hi Chris
I probably did not clear explain what I need.
For example:
we have some domains…
www.test2.com
Now I want to get only the domains to create a new one like:
In case of www.test1.com
mobile.test1.com
In case of www.test2.com
mobile.test2.com
etc…
This should be more dynamically then with a “switch” method:
I think should be something like…
set dom [HTTP:Host]
extract only the domain in this case test1.com build the new FQDN.
I hope I did clearly describe what I mean.
Many thanx
andy
You were there and you didn’t know it! The domain command is your friend: http://devcentral.f5.com/wiki/default.aspx/iRules/domain.html Click Here
So you would want something like this: www2.[domain [HTTP::host] 2]
HTH…Jason
Hi Jason
Thanx for your help…
