Can i prioritize the cipher suites in the ssl profile. For example if I have the following 4 cipher suites, how do I arrange them based on priority. I want them in following order where 1 is the highest priority and 4 is the lowest?
Actually I already did that but it puts the ciphers in the order of no. of bits like first it will put all 256 then 192 then 128 n so on… but not in the order of PFS
PFS would be prioritized by specifying cipher suites that are PFS first. @STRENGTH really isn’t valid any more as it just orders based on bits, not cipher suite. @SPEED is similar as it orders it by smallest bit to largest. i.e.
Apologies if I didnt get your above reply, my query was that I want to set the ciphers in the order that the the Ciphers which offer PFS should come first and than the ones which don’t offer PFS. So is it possible to do this on F5? does your above reply show the ciphers set in the same order that the ciphers which order PFS are placed first and the ones which don’t offer this are placed below??
Thanks man that did the job now I only have 128 bit and 256 bits in the list I also want to include the 192 bit ciphers in the list so is it possible or they all use may be 3DES my current cipher string is as under
