How to parse data group list ?
Hi all,
i have an interresting question about : how to parse element within a data group list ?
In fact, for example if i create a data group with a list of IP addresses (192.168.1.1, 192.168.1.2…), when i try to access to these elements there are braces around them =>: {192.168.1.1}, {192.168.1.2}.
It is an undesirable behaviour, and i just want to know what i have to do to obtain my real IP addresses values without the braces “{” & “}”.
Here is another forum topic related to this issue:
http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&postid=1842
Thanks in advance for your answers.
Environment:
TMMOS 9.4.3
BIG-IP 1500
David
Hi David,
You can use lindex (Click here) to retrieve individual elements of the list. If you’re trying to create a list of IP addresses, it would be more efficient to use a datagroup of type ‘address’ and use the matchclass command (Click here) to check if an IP address/subnet is part of the datagroup.
when RULE_INIT {
 log local0. "\$::aol: $::aol"
 log local0. "\[lindex \$::aol 0\]: [lindex $::aol 0]"
Rule : $::aol: {64.12.96.0/19} {149.174.160.0/20} {152.163.240.0/21} {152.163.248.0/22} {152.163.252.0/23} {152.163.96.0/22} {152.163.100.0/23} {195.93.32.0/22} {195.93.48.0/22} {195.93.64.0/19} {195.93.96.0/19} {195.93.16.0/20} {198.81.0.0/22} {198.81.16.0/20} {198.81.8.0/23} {202.67.64.128/25} {205.188.192.0/20} {205.188.208.0/23} {205.188.112.0/20} {205.188.146.144/30} {207.200.112.0/21}
Rule : [lindex $::aol 0]: 64.12.96.0/19
Aaron
Hi Aaron,
thank you for your answer, it was exactly what i was looking for.
I’ve just tested it, it’s working perfectly.
Thank you so much.
David
