I have a data group where the keys are HTTP paths and the values are a destination URL and a pool. Unfortunately, a group used incorrect pool names and I need to make a mass alteration. My script steps through the pools, finding ones not fitting the nomenclature. I want to create a new pool using the incorrectly-named pool’s members, then delete the old pool. Somewhere in that loop I need to update the data group entries.
For example: pool.x-service.80 members { 1.1.1.1:5000 {} 2.2.2.2:5000 {} }
Should become: pool.x-service.5000 members { 1.1.1.1:5000 {} 2.2.2.2:5000 {} }
I have that code in place and working. But, there are data group entries like this:
ltm data-group class.x-service {
records {
/1/ { data this-server.domain.tld:5000/path/1/ pool.x-service.80 }
/2/ { data that-server.domain.tld:5000/path/2/ pool.y-service.80 }
I cannot figure out how to cycle through the data group. I can grab the data group using tmsh::get_config /ltm data-group class.x-service, but not sure how to step through it entry by entry. For pools and pool members, I am doing the following:
proc script::run {} {
foreach {pool} [tmsh::get_config /ltm pool] {
set poolName [tmsh::get_name ${pool}]
if {${poolName} ends_with ".80"} {
Assume the pool is correctly named
set poolBad 0
foreach poolMemberInfo [tmsh::get_status /ltm pool ${poolName} detail] {
foreach poolMember [tmsh::get_field_value $poolMemberInfo members] {
if {[tmsh::get_field_value ${poolMember} port] != "80"} {
set poolBad 1
set goodPort [tmsh::get_field_value ${poolMember} port]
break
if {$poolBad} {
Pool bad - create new pool"
set newPool [string map {".80" ${goodPort}} ${poolName}]
puts "no-tmsh create /ltm pool ${newPool} { monitor tcp_half_open }"
puts "no-tmsh modify /ltm pool ${newPool} { members add { [tmsh::get_field_value ${poolMember} addr]:[tmsh::get_field_value ${poolMember} port] {} } }"
edit data group entries referring to the wrong pool
set datagroup [tmsh::get_config /ltm data-group class.x-service]
puts "no-tmsh delete /ltm pool ${poolName}"
set datagroup [tmsh::get_config /ltm data-group x-service]
foreach dataGroupEntry [tmsh::get_field_value $datagroup records] {
puts "dg: ${dataGroupEntry}"
Any assistance appreciated.
