How to monitor device status change..
Dear All,
I need your help in checking if we can monitor BIG-IP LTM HA status changes by using monitoring tool. Recently our active LB failed over and we didn’t get any notification. So can someone please help me in providing the procedure for monitoring HA status changes? we are using BEM tool for monitoring our devices..Any help would be appreciated.
BEM tool? http://bem.info/tools/ that one?
you could use SNMP:
and if you using 11.2+ this might be useful:
Thanks for the reply..we are using 9.4.7
You can also send mail from alertd by configuring the traps.
Postfix Configuration
Alertd Configuration
Many thanks.. Will configure this too..
