How to modify information in "meta http-equiv content" section in (response?) header?
Hi everyone. Thank you for taking time to read this post. I am writing this as a Question as the former thread seems to have dropped off the radar.
Basic issue: when a workstation uses a web browser to go to https://psc.company.com, they are receiving back https://backendnode1.company.com in the web browser URL field. We want this to show as “psc” instead of “backendnode1.”
Sounds like a simple case of an iRule. This hasn’t worked (yet); tried a few dozen variations.
Reference previous discussion:
What follows is some simple troubleshooting and the results. I would appreciate your help in understanding those results and how to modify them (likely using a specific iRule).
For brevity and clarity, the actual directory structure listed below is being abbreviated as /tmp.
Executed the following command in order to see what was going on under the hood:
curl [https://psc.company.com](https://psc.company.com) --anyauth --cookie-jar /tmp/psc_cookies.txt --dump-header /tmp/psc_headerdump.txt --cacert /tmp/ca.crt --output /tmp/pscout.txt --trace /tmp/psc_trace.txt
The contents of pscout.txt:
1) Am I correct that it is the HTTP_RESPONSE that includes the information depicted by pscout.txt?
2) The “backendnode1” information is not in the Body of the response. It is my understanding that this means that a STREAM profile will not help. Correct?
3) How can the “meta http-equid content” information be modified using an iRule? Would anyone please provide sample code for this function?
Thank you for any and all input.
John K. Weaver
Note: With help from F5, access policy manager was used to resolve the issue, but the resulting “GUID” in the output is undesirable (instead of https://psc.company.com/websso, the output is something like https://psc.company.com/f5-thisisaverylongstringofgarbledinformation-muchlongerthanthis$$/websso). As such, we are going back to seeking a resolution without the use of APM.
Yes.
The “backendnode1” information ISin the Body of the response.
“the HTTP_RESPONSE” is “the Body of the response”
Add -i to your curl, to include the response headers, in addition to the response “body”.
And yes, a stream profile would be able to modify that html content. DevCentral - An F5 Technical Community
