Can you please let me know which option are converted by using conversion tool for ACE to F5 migration,
and also let me know which options are not converted using conversion tool.
Hi, Have saw this: DevCentral - An F5 Technical Community
Can you please let me know how to use conversion tool from windows pc.
First you have to install Perl in your PC. Then you run the tool script.
Note that the conversion tools on devcentral for Cisco ACE output in version 10.x bigip.conf format, not tmsh commands.
I wrote my own perl script that converts ACE configuration to TMSH commands that can be used for quick import on a 11.x box. You can reach out to me if you want help with your conversions.
Hi Nathan, I am planning on a ACE to F5 (TMSH) migration… Can you plase help with the script that you have.
No problem. You can reach me at nathan.houck@milestonesystems.com
Asfar05, Sure, you can contact me at nathan.houck@milestonesystems.com
I have ace in bridge mode which command scripts in f5 is equivilant ?!?
Hi Nathan, I am planning from ACE to F5 (TMSH) migration can you please share me the script.
Can you share me the script “itsd2001@hotmail.com” thanks.
