How to migrate from Alteon load Balancer to LTM?
We have a pair of HA Nortel Alteon 2424 Load balancers. We recently bought LTM 8900.
Is there any conversion script available to translate the existing Alteon rules to LTM rules and policies?
I found a reference script for Radware to LTM conversion.
Can anybody help? Can anybody has similar experience?
Please share.
Thanks in advance
Hey Haque. I see you also posted a question on the Radware script page. I can’t directly help you I’m afraid but might I suggest getting in touch with F5 support or your F5 representative? I would have thought whoever sold you the 8900’s would be more than willing to help out too.
Can you please send me the location of the script for Alteon to LTM Conversion
Hi, you can find informations on this page : https://devcentral.f5.com/articles/big-ip-configuration-conversion-scripts.Uv3V9XlSlgp
If this script does not work for you, let me know and I will provide you with mine. But it should be the same.
Hi
The radware conversion script doesnt work, it pushes out only the Irule’s, Standard Re-direct rules, persistance profile, protocol profile
None of the Pools, Nodes, and Virtual Servers are exported
Can you assist me further?
Zak
