How to Migrate a Redirect applied to a Single Node on Cisco ACE to F5
Hello Guys,
I am trying migrated VIPs from Cisco ACE to F5 LTM. I have a redirect that is applied a single node in a pool as shown below. I need need to replicate this configuration on F5. Can someone help please.
Node Config:
rserver host websvr01 ip address 10.10.2.5 inservice
rserver host lwebsvr01 ip address 10.10.2.7 inservice webhost-redirection 302 inservice
Pool Config:
serverfarm host actprd probe actprd_probe rserver websvr01 9000 inservice rserver websvr01 9000 inservice
Virtual Server
class-map match-all L4_actprd 1 match virtual-address 10.105.2.1 tcp eq 9000
…Other configs left out
Thank you, Jay
If you can explain the functionality requirement, you may be able to get a better answer. This is a rough untested iRule:
when LB_SELECTED  {
set SERVERIP [LB::server addr]
   if { $SERVERIP eq "10.10.2.7" } {
     HTTP::respond 302 Location "https://domain.com/"
