How to match multiple HTTP headers
I’ve been tasked with creating an iRule that searches for a header of ‘screen’ and field of ‘ABC’. The iRule (or part of iRule) is below:
} elseif {[string tolower [HTTP::header value screen]] equals "ABC" and ${cert-check} != 1 } {
 HTTP::respond 403
(pls ignore the Cert check) The header check seems to be working as expected when 1 header is included, as per below. (Successful test provides a 403, failed test provides a 404).
[root:Active] config  curl -I https://1.1.1.1/ -H "screen: ABC" -k
 HTTP/1.0 403 Forbidden
 Server: BigIP
 Connection: Keep-Alive
 Content-Length: 0
  [root:Active] config  curl -I https://1.1.1.1/ -H "screen: abc" -k
  Server: BigIP
  Content-Length: 0
However when I add two Headers I get (the latter 404 means its not being picked up by the iRule):
[root:Active] config  curl -I https://1.1.1.1/ -H "screen: logon" -H "screen: abc" -k
  Server: BigIP
  Content-Length: 0
  [root:Active] config  curl -I https://1.1.1.1/ -H "screen: abc" -H "screen: logon" -k
  HTTP/1.1 404 Not Found
  Connection: close
  Date: Tue, 08 Oct 2013 23:55:18 GMT
  Content-Length: 1214
  Content-Type: text/html
  X-Powered-By: Servlet/2.4 JSP/2.0
Can anyone identify whats incorrect or needs to be amended on the iRule to resolve this?
sorry iRule should show a lower case abc: } elseif {[string tolower [HTTP::header value screen]] equals “abc” and ${cert-check} != 1 } { HTTP::respond 403
It’s a little odd because this appears to actually work with multiple headers in 11.3:
    if { [string tolower [HTTP::header screen]] equals "abc" } {
        log local0. "match"
What version are you on?
In lieu of the above, you could also iterate through the list of headers like this:
    foreach x [HTTP::header names] {
        if { ( $x equals "screen" ) and ( [string tolower [HTTP::header $x]] equals "abc" ) } {
            log local0. "match"
            break
Version 10.2.3
Just to test, try switching the abc value to the second header and screen to the first. This should prove it’s only reading the last header.
Hi ‘What Lies Beneath’ the test you are requesting is detailed previously
