Hi there,
I’m new to iRules and trying to come up with a solution here and hoping someone can help. I have two URLs:
1) http://www.abc.com/join
2) http://www.abc.com/join/events
I would like the 2nd one to stay http://www.abc.com/join/events in the URL bar when the user types it but redirect behind the scenes to http://www.abc.com/join
Is that possible?
Thanks,
George
The following should work for you
if { [HTTP::uri] equals “/join/events” } {
HTTP::uri “/join”
Unfortunately that did not work as I receive the following 404 error:
HTTP Status 404 - /join/events/
type Status report
message /join/events/
description The requested resource (/join/events/) is not available.
That’s because the iRule is comparing the string “/join/events” and you passed in “/join/events/”.
Something like this should work
if { [HTTP::uri] equals "/join/events/" } {
HTTP::uri "/join"
But, that would ONLY match a url of “/join/events/”. “/join/events”, “/Join/Events/”, etc would not match.
You could also use a “starts_with” to compare like this
if { [HTTP::uri] starts_with "/join/events" } {
HTTP::uri "/join"
That would match “/join/events” and “/join/events/” but it would also match on “/join/eventsFOOBAR” or anything else after events in the URI.
If you want to have more options in your comparisons, I’d use a switch statement with the “string tolower” on the URI.
switch -glob [string tolower [HTTP::uri]] {
"/join/events" -
"/join/events/" {
HTTP::uri "/join"
Lots of options, it really depends on your app logic how complex you want to go with the comparison.
-Joe
Many thanks Joe!
The switch statement with the “string tolower” did it. And now I know that much more about iRules.
Thanks,
George
The customer has now changed the requirements.
They would like the 2nd one to stay http://www.abc.com/join/events in the URL bar when the user types it but redirect behind the scenes to a different server entirely: .xyz Domain Names | Join Generation XYZ
What is the proper command string to make that work unbenownst to the end user?
