How to logging SNAT Pool translation list with irules?
We dooes configurae Link Controller Loadbelance outbound traffic to Internet with SNAT Pool public IP.
We need to logging translation list
CLient Address --> Public IP --> Remote Address
Best Regards,
You should be able to adapt a rule like this to log the original client, SNAT and destination IP addresses:
when SERVER_CONNECTED {
    log local0. "[IP::client_addr], [IP::local_addr], [IP::server_addr]"
I haven’t tested this with a link controller, but I think a layer4 based iRule should work okay.
Aaron
Should work, but I’d be careful with putting a rule like this on a high-volume site…you don’t want to fill up /var/log and cause performance problems.
Denny
If you are on 9.4 or higher you can send directly to a remote log server so you can log higher volumes without being impacted by the disk access necessary for local writes:
log x.x.x.x local0.info “[IP::client_addr], [IP::local_addr], [IP::server_addr]”
