How to limit number concurent sessions per user IP on F5
Dear Gents,
I would like to ask about idea how is possible restrict number TCP concurrent sessions per a user source IP. Moreover I am interested if is possible to create static list (just 10 IPs) of source IPs for which si such restriction enforced. Any idea would be highly welcomed. Many thanks, Regards Andy
Hello Andrej.
It’s very simple to do it with APM
But you can use it also with an iRule (there are many on devcentral).
KR,
Dario.
Dario many thanks for nice references but my concern is a bit more complex. I would like to restrict number of TCP connection just for dedicated 5 IP addresses on LAN network. I am looking for information how to create some static list of IP@ or define those host for which I just want enforce maximum number of TCP sessions. Other IP outside of list would be unrestricted. Any idea how to define such static IP list?
This is very simple to get it.
You can set a condition to not execute the additional code if the source IP doesn’t match a data-group called “my_ip_dg”.
when CLIENT_ACCEPTED {
    if { not ( [class match [IP::client_addr] equals my_ip_dg] ) } {
        return
when CLIENT_CLOSED {
        return
If you have the chance, I recommend you to implement your connection limit using table variables. Here an example.
https://devcentral.f5.com/s/articles/advanced-irules-tables-20451
KR,
Dario.
