How to know which monitor is down/up ?
I setup snmp trap and get these msgs:
18:53  * pixnethea f5-6400-2-mgt 18:52:47:"10.1.1.180:80 monitor status down ."
  18:53  * pixnethea f5-6400-2-mgt 18:52:49:"10.1.1.152:81 monitor status down ."
  18:53  * pixnethea f5-6400-2-mgt 18:52:50:"10.1.1.180:80 monitor status up ."
  18:53  * pixnethea f5-6400-2-mgt 18:52:51:"10.1.1.152:81 monitor status up ."
  18:54  * pixnethea f5-6400-2-mgt 18:54:25:"10.1.1.228:3128 monitor status down ."
  18:54  * pixnethea f5-6400-2-mgt 18:54:27:"10.1.1.228:3128 monitor status up ."
  18:55  * pixnethea f5-6400-2-mgt 18:54:41:"10.1.1.53:80 monitor status down ."
  18:55  * pixnethea f5-6400-2-mgt 18:54:43:"10.1.1.134:80 monitor status down ."
  18:55  * pixnethea f5-6400-2-mgt 18:54:44:"10.1.1.184:3128 monitor status down ."
  18:55  * pixnethea f5-6400-2-mgt 18:54:45:"10.1.2.106:80 monitor status down ."
  18:55  * pixnethea f5-6400-2-mgt 18:54:46:"10.1.1.228:3128 monitor status down ."
  18:55  * pixnethea f5-6400-2-mgt 18:54:47:"10.1.1.53:80 monitor status up ."
  18:55  * pixnethea f5-6400-2-mgt 18:54:48:"10.1.1.184:3128 monitor status up ."
  18:55  * pixnethea f5-6400-2-mgt 18:54:50:"10.1.1.134:80 monitor status up ."
  18:55  * pixnethea f5-6400-2-mgt 18:54:51:"10.1.2.106:80 monitor status up ."
  18:55  * pixnethea f5-6400-2-mgt 18:54:52:"10.1.1.228:3128 monitor status up ."
  18:56  * pixnethea f5-6400-2-mgt 18:56:12:"10.1.2.124:80 monitor status down ."
  18:56  * pixnethea f5-6400-2-mgt 18:56:13:"10.1.2.101:80 monitor status down ."
  18:56  * pixnethea f5-6400-2-mgt 18:56:14:"10.1.2.104:80 monitor status down ."
  18:56  * pixnethea f5-6400-2-mgt 18:56:17:"10.1.2.104:80 monitor status up ."
  18:56  * pixnethea f5-6400-2-mgt 18:56:19:"10.1.2.124:80 monitor status up ."
  18:56  * pixnethea f5-6400-2-mgt 18:56:20:"10.1.2.101:80 monitor status up ."
  19:00  * pixnethea f5-6400-2-mgt 19:00:09:"10.1.1.180:80 monitor status down ."
  19:00  * pixnethea f5-6400-2-mgt 19:00:11:"10.1.1.186:80 monitor status down ."
  19:00  * pixnethea f5-6400-2-mgt 19:00:12:"10.1.2.127:81 monitor status down ."
  19:00  * pixnethea f5-6400-2-mgt 19:00:13:"10.1.1.180:80 monitor status down ."
  19:00  * pixnethea f5-6400-2-mgt 19:00:14:"10.1.2.116:80 monitor status down ."
  19:00  * pixnethea f5-6400-2-mgt 19:00:15:"10.1.1.155:80 monitor status down ."
  19:00  * pixnethea f5-6400-2-mgt 19:00:17:"10.1.1.186:80 monitor status up ."
  19:00  * pixnethea f5-6400-2-mgt 19:00:18:"10.1.1.180:80 monitor status up ."
  19:00  * pixnethea f5-6400-2-mgt 19:00:19:"10.1.2.127:81 monitor status up ."
  19:00  * pixnethea f5-6400-2-mgt 19:00:20:"10.1.2.116:80 monitor status up ."
  19:00  * pixnethea f5-6400-2-mgt 19:00:21:"10.1.1.180:80 monitor status up ."
  19:00  * pixnethea f5-6400-2-mgt 19:00:23:"10.1.1.155:80 monitor status up ."
These didn’t mention which monitor is down. How should I get monitor information ?
See this post for details on a db key change you can make to get the monitor name:
b db bigd.lognodestatuschange enable
Email notification of node/vs down
http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&postid=20167&ptarget=28526
Aaron
Yes, I’ve seen monitor name in /var/log/ltm now, but not snmp trap msgs. I’ve tried to modify “MCP” in “System > Logs > Options” to “debug” level but in vain.
I’m not sure whether it’s possible to get the monitor name in a standard SNMP alert. You might be able to create a custom SNMP trap based on the log message which contains the monitor name. Try searching AskF5.com and/or this forum for “custom snmp trap” for some examples.
SOL10966 notes a request for enhancement CR, CR82787, to support the logging of the monitor name in the logs. You might open a case with F5 Support referencing this CR and ask if it already includes SNMP traps in the RFE. If not, they could add this feature to the request.
SOL10966: Determining which monitor triggered a change in the availability of a node or pool member
Aaron
