how to integration vpn mva and owa
hi expert
i wnat to integration vpn mva and owa the flow like this
i have no idea how to apply the user want ato access email and otp send to sms gateway
thanks
I think you need to find a competent partner and procure professional services for architecture design and potential assistance with implementation.
I agree if @whisperer if you really haven’t done something like this before. Reach out to your F5 partner or reseller if you have one.
Else you can search for OWA DUO F5 documents, there are some suggestions here: https://community.f5.com/t5/technical-forum/two-factor-authentication-for-owa-with-f5-apm-and-duo/td-p/241683
Beyond that DUO seems to do this also with an own plugin: Duo 2FA for Outlook Web App Subscription Edition (SE) | Cisco Duo
