How to Integrate F5 Anti-Virus with Fortisandbox using ICAP
Helo!
i have a question is there possible if i integrate Anti-Virus on F5 with Fortisandbox?
Because, i will create an feature on web application for uploading file with xlsx and pdf format. I want to send the file for scanning on fortisandbox before pass to the server.
ive read some article myF5
but i still wondering, is it possible or not?
thank you.
Be aware that the icap interface of bigip is limited to 20mb. I never noticed a change in this behaviour.
You may check my article F5 ICAP over SSL/TLS (Secure ICAP) with F5 ASM/AWAF Antivirus Protection feature | DevCentral as it shows how to do it for LTM or AWAF/ASM and the benefits and limitations and how to optime the traffic send to ICAP as to be only files as @Torti   mentioned that there are limits.
can you share any article as reference for me?
ive read the article, i want to know more deeply about its benefit and weakness if i integrate ICAP server directly on module awaf/asm antivirus method and by your article (create LTM for ICAP Server)?
I have described everything in the article :wink:
