What iRules I will use to include information about IP address(es) of some balanced Web Servers into HTTP Header?
Here is an iRule to include Web servers adresses into the header.
when HTTP_RESPONSE {
HTTP::header insert Server_IP "[IP::server_addr]:[TCP::server_port]"
I need to insert this info to HTTP Header only for some servers, not for all
You can create a data group with all servers for which you want to insert this information.
Then when your data group is created, your iRule will be :
if { [class match [IP::server_addr] equals my_ip_datagroup] } {
Can I use following iRule for pool which has name Pool_Name?: when HTTP_RESPONSE{ if {pool } {HTTP::header insert Server_IP [IP::server_addr]} }
Here is an iRule with the condition based on the pool choosen :
if { [LB::server pool] equals your_pool_name } {
Is your iRule going to be applied on multiple virtual servers ?
