Just wanted to share the steps for running BIG-IP VE in VirtualBox. This was tested on 12.1.2 running inside of Virtualbox 5.1
Prerequisites
- Virtualbox instance (5.1.12)
- 12.1.2 VE image (BIGIP-12.1.2.0.0.249.ALL-scsi.ova)
Procedure
- Create a “working folder” for your Virtualbox OVA
- mkdir ~/virtualbox-ve
- Copy your OVA to this folder
- Extract the files from the OVA
- tar xvf BIGIP-12.1.2.0.0.249.ALL-scsi.ova
- Make a copy of the OVF in case you need to revert
- cp BIGIP-12.1.2.0.0.249-scsi.ovf BIGIP-12.1.2.0.0.249-scsi.ovf.original
- Delete the manifest file
- rm BIGIP-12.1.2.0.0.249-scsi.mf
- Find the disk2 definition in the OVF file using your favorite CLI editor (vi).
<item>
<rasd:AddressOnParent>0</rasd:AddressOnParent>
<rasd:ElementName>disk2</rasd:ElementName>
<rasd:HostResource>ovf:/disk/vmdisk2</rasd:HostResource>
<rasd:InstanceID>6</rasd:InstanceID>
<rasd:Parent>3</rasd:Parent>
<rasd:ResourceType>17</rasd:ResourceType>
</item>
- Change the disk2 AddressOnParent from 0 to 1
- Change the disk2 Parent from 3 to 4
- Remove the secondary SCSI controller definition by removing this section from the OVF:
<item>
<rasd:Address>1</rasd:Address>
<rasd:Description>SCSI Controller</rasd:Description>
<rasd:ElementName>scsiController1</rasd:ElementName>
<rasd:InstanceID>3</rasd:InstanceID>
<rasd:ResourceSubType>lsilogic</rasd:ResourceSubType>
<rasd:ResourceType>6</rasd:ResourceType>
</item>
- Save the OVF file in the editor and quit.
- Import the image via the OVF file (not the OVA!) You can try repackaging this into an OVA but YMMV.
- Change the network adapter types to virtio-net.
- Start up the imported VM.
