To implement DevOps on our F5 install (which uses version 11.5.3), we have developped a set of Python script, that rely upon
tmsh load sys config merge file
and template files to add elements to f5 config.
We’re curretnly trying to automate installation of our APM policy, which requires logon page. Unfortunatly, installation of a logon page requires a customization and I found no way to import a customization group into BigIP. So far, what I do is import the following file,
apm policy customization-group /SDU_01_rin/SDU_01_PORTAIL_APM_PROFILE_beta_APMBranch {
cache-path /config/filestore/files_d/SDU_01_rin/customization_group_d/:SDU_01_rin:APMBranch::APMBranch__15760_1
type logon-page
revision 1
partition SDU_01_rin
Which always triggers the following error message
Syntax Error: "tmsh" unknown property
Obviously, the cache-path value,
, is, at the time this command is invoked, already created with the following content
So, what can I do in order to import that empty customization group ?
