How to identify the difference in the Act/Stdby Configuration on the vCMP guest
Dear F5 Experts.
I need help with identifying the differences between the Active and Standby vCMP guest, Someone accidentally made some changes on the Standby guest, Now I am adding configs to the Active guest and when I try to sync, I see this message
“One or more devices has a more recent configuration that the selected device,To overwrite the more recent configuration, you must use the Overwrite Configuration option”
Can somebody help me how to identify the differences so that I am not overwriting.
Thanks Balaji
You can compare both device file with size, audit log, etc(ls -l bigip.conf).
Other option is to compare both device file via unix command.
comm -13 <(sort file1) <(sort file2) > file3
or
grep -Fxvf file1 file2 > file3
or
diff file1 file2 | grep "<" | sed 's/^ file3
