I think that the UIE peristence table is created for each pools.
Is it possible to execute “persist lookup uie” command for the each pools ?
persist lookup [all|node|port|pool]
“all” or no specification returns a list containing
the node, port and pool name. Specifying any of the other
return types will return the specified item only.
For example, I want to get the both of “the persistence node of pool_1” and “the persistence node of pool_2” with the command “persist lookup uie”.
I can’t set pool name for the command “persist lookup uie 11111111 node”.
( The command “persist lookup uie 11111111 node” works. it returns “10.4.10.201”. But I can’t get the persistence node for each pools.)
Would you advice me ?
<< The two same peristence tables for each pools (pool_1 and pool_2) are created on BIG-IP >>
b persist pool pool_1 show all
PERSISTENT CONNECTIONS --
Mode: universal Value: 11111111
Virtual: 192.168.0.200:https Node: 10.4.10.201:80 Age: 14sec
[root@emylb202:Active] config b persist pool pool_2 show all
Virtual: 192.168.0.200:https Node: 10.4.10.201:80 Age: 10sec
b persist all show all
Thanks in advance,
