HI Friends
How to get the f5 device current power consumption? TMSH or SNMP?(Which one OID?)
I find the “tmsh show sys hardware” command No power consumption display.
Thanks D.luo
HI Friends
Thanks D.luo
Are you trying to see if there is a way to identify the total power consumed at any point in time ? or total power available ?
I don’t think a device can show how much power it uses itself via its resident software. You would need to install an electric metre in front of the device in order to measure accurately how much current is drawn by that device.
