hi,friends: i have a question..HOW TO GET SYSTEM CPU Usage by icontrols?
What method should be invoked to get CPU utilization on the BigIP? like this…
Did you try to get with method “get_all_cpu_usage_extended_information” in namespace “System.SystemInfo”? I think is there.
Anybody know?
Anybody know?
dont believe that is possible in the GUI
you can you top in the CLI to check processes, but not sure if icontrol jumps out then.
I’d also like to know if it is possible to get CPU history data via iControl so that I can plot it myself. Or is there a way to get the complete graph via iControl?
