HOW TO GET CPU USAGE IN BigIP::iControl ?
hi,friends: i want to get the cpu usage by the method that’s get_cpu_usage_extended_information_stringified…but it is error!
500 Internal Server Error at /usr/lib/perl5/site_perl/5.8.8/BigIP/iControl.pm line 599
the code :
!/usr/bin/perl
use warnings;
use strict;
use BigIP::iControl;
use Data::Dumper;
my $ic = BigIP::iControl->new(
                                server          => '10.1.1.1',
                                username        => 'admin',
                                password        => 'abc123',
                                port            => 443,
                                proto           => 'https'
my $cpu=$ic->get_cpu_usage_extended_information_stringified();
print (Dumper($cpu)."\n");
[abc@localhost F5iControl]$ perl GetConfig.pl
can u help me ?? ths…
I’m not sure about BIGIP::iControl, but here’s some code to do it in Perl with SOAP::Lite. I just updated the System Usage CodeShare sample to include the get_cpu_usage_extended_information() method.
Hope this helps…
-Joe
THINKS FOR YOUR help~o(∩_∩)o… It’s success…
Glad to help!
