One of the questions we get asked a lot in the DevCentral Community is, ‘How to I get a #Trial or lablicense?’ There are a few easy ways to test f5 services.
First, you can go to the F5 Product Trials | F5 page. There, you can select various options to meet your needs. Simply click on the Get the free trial button, enter the pertinent info and off you go.
Out in the Cloud, you can get a free, full featured 30-day trial as well as access to F5 premium support on AWS, Azure, GCP and Alibaba.
If you need a perpetual, single use Lab license to do your own testing, learning, practicing, you can purchase a Lab License for around $100 or so depending on where you go.
Thanks you very for your post and video on how to get an F5 trial or lab License, as I’ve been wanting this for a while but didn’t know how to obtain it.
I want to test, learn, and practice on F5 LTM, so this is a perfect solution for my need.
