Problem this snippet solves:
When you configure a cookie persistence profile to use the HTTP Cookie Insert or HTTP Cookie Rewrite method, the BIG-IP system inserts a cookie into the HTTP response. The cookie value contains the encoded IP address and port of the destination server. Exemple of a cookie value : 1677787402.36895.0000
(See SOL6917 for more information about this topic)
Let’s assume that you want your pool member to receive a copy of this cookie value in an HTTP header. Because for example you want your application to forge an url where the cookie value is in a GET parameter. (NOTE : I cannot modify the behavior of the application, I can only play with headers)
Retrieving the cookie value is pretty easy with iRule : [HTTP::cookie value $cookie_name]
But you’ll notice that there is a little issue with this feature: when you are a new visitor, the persistence cookie is inserted in the HTTP response … Meaning that for the very first hit made by the visitor, there will be NO cookie value to retrieve …
In my scenario it was an issue to miss this cookie value on the first hit, so I had to come up with a solution to forge the cookie value based on pool member IP and port when the persistence cookie is missing.
I chose to adapt the code found here and there (thanks !)
EDIT : Well I figured out that if you are not using a default route-domain the persistence cookie value will be different (see myF5 )
Here is the alternative code bloc to use IPv4 non-default route domains:
set ADDR "[format %02x $a][format %02x $b][format %02x $c][format %02x $d]"
set PORT [LB::server port]
set COOKIE "rd2o00000000000000000000ffff${ADDR}o${PORT}"
How to use this snippet:
To summarize what the iRule does : if the persistence cookie doesn’t exist (most likely because it’s the very first hit), then calculate it from member IP and PORT (it obviously has to be after the “When LB_SELECTED” statement) ; else just read the existing cookie.
You can set the $cookie_name parameter manually, or let the iRule identify it
Code :
when LB_SELECTED {
#set cookie_name SERVERID
# following function could determine persistence cookie name being used if not manually set by the previous line
if {not [info exists cookie_name]} {
if { [set cookie_name [PROFILE::persist mode cookie cookie_name]] eq "" } { set cookie_name "BIGipServer[getfield [LB::server pool] "/" 3]" }
#Default cookie name requires the getfield "/" 3 purge otherwise it's /Common/pool_name
if { [set COOKIE [HTTP::cookie value $cookie_name]] == "" } {
scan [LB::server addr] {%d.%d.%d.%d} a b c d
set ADDR [expr { $a + $b * 256 + $c * 65536 + $d * 16777216 }]
set PORT [ntohs [LB::server port]]
set COOKIE "${ADDR}.${PORT}.0000"
## Following bloc must be used instead if you are using non-default route domains, see K6917
#set ADDR "[format %02x $a][format %02x $b][format %02x $c][format %02x $d]"
#set PORT [LB::server port]
#set COOKIE "rd2o00000000000000000000ffff${ADDR}o${PORT}"
unset a b c d ADDR PORT
#log local0. "$cookie_name = $COOKIE created for [HTTP::uri]"
#log local0. "$cookie_name = $COOKIE already exists for [HTTP::uri]"
HTTP::header insert X-F5-persist $COOKIE
Tested this on version:
11.5
