how to forward an optinional requested cleint cert in header
Hi Ladies & Gentlemen!
I am beginner with BigIp and has to solve the next problem.
The Client X.509 cert should be requested, and if existing it has to be forwarded via http to the backend application. In case of forwarded correct cert user auth is done, otherwise login and password will be required.
Client Cert should be requested only once an forwarded in header.
My iRules shows, that SSL negitiation happens two time. The first gets the cert, the second removes it immediatelly.
Does anybody have a hint for me?
Here my iRules and the logs :
snip
when CLIENT_ACCEPTED {
Triggered when a client has established a connection.
log LOCAL0.warn “IN CLIENT_ACCEPTED”
set certState 0
set clientCrt “”;
set clientCN “”;
when CLIENTSSL_HANDSHAKE {
Triggered when ?
if { [SSL::cert count] > 0 }{
log LOCAL0.warn “IN CLIENTSSL_HANDSHAKE; client has a cert”
else {
log LOCAL0.warn “IN CLIENTSSL_HANDSHAKE; no client cert detected”
when CLIENTSSL_CLIENTCERT {
Triggered when the system adds an SSL client certificate to the client certificate chain.
log LOCAL0.warn “IN CLIENTSSL_CLIENTCERT; client has a cert”
set clientCrt [SSL::cert 0];
set clientCN [X509::subject $clientCrt];
log LOCAL0.warn [concat "CN:= " $clientCN];
else {
log LOCAL0.warn “IN CLIENTSSL_CLIENTCERT; no client cert detected”
Triggered when the system fully parses a complete client request header.
log LOCAL0.warn “START HTTP_REQUEST”;
persist cookie insert lmn-cookie
use pool http_TE7
log LOCAL0.warn “START HTTP_REQUEST in Appl”;
log LOCAL0.warn [concat "--CN:= " $clientCN];
log LOCAL0.warn “IN extra , client has cert”;
set clientCrtMas [SSL::cert 0];
HTTP::header insert “SSL_CLIENT_CERT” [X509::whole $clientCrtMas];
log LOCAL0.warn “IN HTTP_REQUEST; cert HEADER SSL_CLIENT_CERT inserted”;
log LOCAL0.warn “IN extra , client has NO cert, then NO HEADER”;
the logs :
Fri Jun 30 01:00:21 CEST 2006 tmm tmm[695] Rule sp_7 : IN CLIENT_ACCEPTED
Fri Jun 30 01:00:27 CEST 2006 tmm tmm[695] Rule sp_7 : IN CLIENT_ACCEPTED
Fri Jun 30 01:00:35 CEST 2006 tmm tmm[695] Rule sp_7 : IN CLIENTSSL_CLIENTCERT; client has a cert
Fri Jun 30 01:00:35 CEST 2006 tmm tmm[695] Rule sp_7 : CN:= /DC=de/CN=People/serialNumber=2446372846/CN=Testuser910
Fri Jun 30 01:00:35 CEST 2006 tmm tmm[695] Rule sp_7 : IN CLIENTSSL_HANDSHAKE; client has a cert
Fri Jun 30 01:00:39 CEST 2006 tmm tmm[695] Rule sp_7 : IN CLIENT_ACCEPTED
Fri Jun 30 01:00:39 CEST 2006 tmm tmm[695] Rule sp_7 : IN CLIENTSSL_HANDSHAKE; no client cert detected
Fri Jun 30 01:00:39 CEST 2006 tmm tmm[695] Rule sp_7 : START HTTP_REQUEST in Appl
Fri Jun 30 01:00:39 CEST 2006 tmm tmm[695] Rule sp_7 : --CN:=
Fri Jun 30 01:00:39 CEST 2006 tmm tmm[695] Rule sp_7 : IN extra , client has NO cert, then NO HEADER
Fri Jun 30 01:00:39 CEST 2006 tmm tmm[695] Rule sp_7 : CN:=
end of logs
Best regrads
Soponyai
The problem is reduced currently to a client verification problem. Here the logs
: IN CLIENTSSL_HANDSHAKE; client cert verification := 21
: IN CLIENTSSL_HANDSHAKE; unable to verify the first certificate
Although the certificate if the isuuer of the client certificate is imported and to tho ssl_profile assigned, the cer will not be accepted.
The problem is further reduced.
After succesfully received and verified the cleint cert,
a RENEGOTIATION of the connection will done !
See protocol extract :
: IN CLIENTSSL_HANDSHAKE; client cert verified ok
So the cert can not be forwarded to the application:
: IN HTTP_REQUEST; client has NO cert, then NO HEADER; CN:=;
Please for hints, what can it be caused by.
Regards
