I want to limit magager ports ,I found manager port can’t through port Lockdown ,also can’t through packet filter . Do you have other ideas ?
The MGMT port should only be attached to a Secure Management network, its kind of by design.
You should ideally lock it down with Firewall rules on an adjacent device, VLAN segregation etc.
Presuming that you wish to restrict access by netblock, you can restrict ssh access on the management interface:
and separately do the same for TMUI (the Web UI):
3Q
3Q
