hello
can anyone help me fixing this issue. Memory critical utilization above 95% detected on F5 load balancer how to resolve this issue .. Please advice
hello
95% is critical. Have you checked if the memory utilization is above 95% or not. If it’s above find out the process that is utilizing memory.
You may want to use commands like free top
thanks
I checked the F5 and found this Total Phys Memory 6.8G 6.8G 6.8G OS Used Memory 6.7G 6.7G 6.7G TMM Alloc Memory 5.5G 5.5G 5.5G TMM Used Memory 96.9M 96.8M 96.9M OS Used Swap 5.3M 5.3M 5.3M ------------------------ Sys::Host Memory (bytes) ------------------------ Host: 0 Available 6.8G Used 6.7G
Hi dev babu can you please provide detailed step by step troubleshooting to fix the issue through tmsh please
tmm used memory is not high, is it?
sol15468: Overview of BIG-IP TMM CPU and memory usage (10.x - 11.x)
