How to fix apache struts2 s2-045 vulnerable with f5 irule ?
Hi Robinchien,
you need to either create a whitelist containing your allowed
Content-Type
request-header values (most secure but sligthly difficult approach) or black-list certain characters (e.g.
or
) and attack-patterns (e.g.
ognl
memberaccess
getruntime
exec
), which will unlikely used by your application but required to pulloff the s2-045 remote execution (less secure but easy to implement).
Whitelist approach:
    switch -exact -- [string tolower [HTTP::header value "Content-Type"]] {
        "multipart/form-data" -
        "text/xml; charset=utf-8" -
        "application/x-www-form-urlencoded" {
             Allow request with empty or white listed "Content-Type" headers
        default {
             Reject request with unknown "Content-Type" headers
            reject
Blacklist approach:
    switch -glob -- [string tolower [HTTP::header value "Content-Type"]] {
        "*ognl*" -
        "*memberaccess*" -
        "*getruntime*" -
        "*exec*" {
             Reject requests with suspicious "Content-Type" headers
            reject
        default {
             Allow request with unsuspicious "Content-Type" headers
Cheers, Kai
The Vulnerability has to do with File upload so, no use checking every single request.
This is why my iRule on codeshare inspects the Content-Type for POST requests only.
Here.
      if { [HTTP::method] equals "POST" } {
            if { not ( [HTTP::header Content-Type] equals "multipart/form-data" or [HTTP::header Content-Type] equals "application/x-www-form-urlencoded" or [HTTP::header Content-Type] equals "text/plain" ) } {
                reject
                log local0. "Rejecting a POST request with Content-type [HTTP::header Content-Type]  to  [HTTP::uri]  from  [IP::client_addr]"
One could restrict this further by matching against the URL(s) which present the upload form:
      if { [HTTP::uri] equals "" } {
                reject
There is now an official fix: Final - K43451236: Apache Struts 2 vulnerability CVE-2017-5638.
This answer shouldn’t be marked as answer. Its breaking applications and also not covering all attack vectors.
Cheers, Kai
