How to filter client access based on source IP and URI
For a webservice we have to give clients access to a specific uri, but only from a specified list of ip adresses. So access to www.site.foo/uri1 only from 1.1.1.1 and 1.1.1.2 and access to www.site.foo/uri2 only from 2.2.2.1 and 2.2.2.2. And that for 106 uris and about 10 ip adresses per uri.
Is there a best practice for this? Using an iRule? Or using an access policy? Any idea is more than welcome.
Thanks in advance.
Regards,
Richard
I think you would have to identify some kind of pattern in order to see if you can have a simplified iRule. As a general suggestion, datagroup containing IP addresses can be used to match on client IP.
If there is only 1 IP or a single network, you can try to leverage the key:value aspect of the datagroup and use something like this “1.1.1.1:=/uri1” i.e., identify the allowed uri based on the matched key (IP Address).
If you know any geographic information of the client IP, you can explore the whereis option in iRule.
I think that, you may use irule which consists of datagroups and class-match.
Hi Richard,
you may try one of the following examples…
Example 1: Using a single datagroup to assign allowed IPs to restricted URIs
Datagroup (DG_MY_URI Type STRING):
"/folder1" := "1.1.1.1 2.2.2.2 3.3.3.3 4.4.4.4"
"/folder2" := "1.1.1.1 2.2.2.2"
"/folder3" := "3.3.3.3 4.4.4.4"
"/folder4" := "5.5.5.5"
iRule:
    if { [set uri_result [class match -value [string tolower [HTTP::path]] starts_with DG_MY_URI]] ne "" } then {
        if { [lsearch -inline $uri_result [IP::client_addr]] eq "" } then {
            HTTP::respond 403 content "Access denied..." "Content-Type" "text/html"
             Allow trusted IP
         Allow requests to unknown URIs
Example 2: Using two datagroups to support a “kind of” object based ACL.
"/folder1" := "Internal Customer1 Customer2 Customer3"
"/folder2" := "Internal Customer2 Customer3"
"/folder3" := "Internal Customer3"
"/folder4" := "Location1 Location2"
IP Datagroup (DG_MY_IP Type IP-Adrress):
"10.0.0.0/8" := "Internal"
"10.10.10.0/24" := "Internal Location1"
"10.10.11.0/24" := "Internal Location1"
"10.10.12.0/24" := "Internal Location1"
"10.10.13.0/24" := "Internal Location1"
"10.10.14.0/24" := "Internal Location2"
"10.10.15.0/24" := "Internal Location2"
"10.10.16.0/24" := "Internal Location2"
"10.10.17.0/24" := "Internal Location2"
"111.111.111.111" := "Customer1"
"172.16.0.0/12" := "Internal"
"190.190.190.190" := "Customer2"
"192.168.0.0/16" := "Internal"
"212.212.212.212" := "Customer3"
iRule:
when CLIENT_ACCEPTED {
    set ip_result [class match -value [IP::client_addr] equals DG_MY_IP]
        if { $ip_result eq "" } then {
             Disallow the request
            foreach uri_entry $uri_result {
                if { [lsearch -inline $ip_result $uri_entry] ne "" } then {
                     Allow trusted IP
                    return
        return
     Trigger the error page...
Cheers, Kai
