How to display big ip virtual edition appliance serial number (ex. "ZWIFNYAR")
Does anyone know how to display the appliance serial number on a virtual edition BIG-IP? It’s an eight-character serial # that begins with a “Z” (all of ours start with “Z” so I’m assuming…). It shows up on purchase orders for virtual edition appliances, but I have no idea where they get it from. When it’s time to renew maintenance that’s how the vendor references them (then I’m asked, “Are these ours?”).
Thanks!
Hello Alan.
"A BIG-IP Virtual Edition (VE) system does not have a similar serial number format to the previously mentioned hardware platforms. If you encounter any issue that requires F5 Support assistance, you cannot use the BIG-IP VE serial number to open a support case. You must use the last seven digits of the BIG-IP VE registration key.
Note: For information about finding the registration key of your BIG-IP virtual edition (VE) system, refer to K54213125: Finding the registration key of your BIG-IP virtual edition (VE) system"
REF - myF5
So, the code you are searching should be ‘Z’ + your last 7 digits of your license.
REF - myF5
KR,
Dario.
