Hello!
I am looking for some thing in LTM device [BIG-IP 10.2.0 Build 1789.0 Hotfix HF2]
I want to disable all management access (https/ssh/snmp etc) on the specific IPs for load balancers.
Please Help to to resolve this issue.
Thanks in advance.
Hello!
Thanks in advance.
G_C
Network - Self IPs - Port Lockdown. Is this what you’re after?
Hope this helps
N
Oh, thanks!
I think that it is necessary for me, but one more question: Network - Self IPs - Port Lockdown and there I can choose 3 options:
-Allow default
-Allow none
-Allow custom
-Allow all
what should I choose for my goal?
G_C
Possibly Allow None from your initial post but here’s the Help information.
Port Lockdown
Allow Default: Activates only the following protocols and services:
UDP: DNS (53), SNMP (161), RIP (520), iQuery (4353)
TCP: SSH (22), DNS (53), SNMP (161), HTTPS (443), iQuery (4353)
Allow All: Activates all TCP and UDP services on this self IP.
Allow None: Specifies that this self IP accepts no traffic.
Allow Custom: Expands the Custom List option, where you can specify the protocols and services to activate on this self IP.
Rgds
N
Thank you!
Thank you!
