How to detect config sync status using iControl
Is there some way to detect ‘config sync status’ using iControl ?
I would like to get this info using iControl?
CONFIG SYNC STATUS --
     Status:  0 - Synchronized
     Last change (Self):  2005-06-30 13:54:02
     Last change (Peer):  2005-06-30 14:16:49
     Last Configsync:  2005-06-30 14:16:49
These values are stored in the internal database which can be accessed via the Management::DBVariable interface.
The values you are looking for are:
“configsync.autodetect”
“configsync.localconfigtime”
“configsync.peerconfigtime”
“configsync.localsyncedtime”
“configsync.state”
Here’s some sample code in perl to mimic the “bigpipe config sync show” command.
!/usr/bin/perl
  The contents of this file are subject to the "END USER LICENSE AGREEMENT
  FOR F5 Software Development Kit for iControl"; you may not use this file
  except in compliance with the License. The License is included in the
  iControl Software Development Kit.
  Software distributed under the License is distributed on an "AS IS"
  basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See
  the License for the specific language governing rights and limitations
  under the License.
  The Original Code is iControl Code and related documentation
  distributed by F5.
  The Initial Developer of the Original Code is F5 Networks,
  Inc. Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2004
  F5 Networks, Inc. All Rights Reserved.  iControl (TM) is a registered
  trademark of F5 Networks, Inc.
  Alternatively, the contents of this file may be used under the terms
  of the GNU General Public License (the "GPL"), in which case the
  provisions of GPL are applicable instead of those above.  If you wish
  to allow use of your version of this file only under the terms of the
  GPL and not to allow others to use your version of this file under the
  License, indicate your decision by deleting the provisions above and
  replace them with the notice and other provisions required by the GPL.
  If you do not delete the provisions above, a recipient may use your
  version of this file under either the License or the GPL.
 use SOAP::Lite + trace => qw(method debug);
 use SOAP::Lite;
 BEGIN { push (@INC, ".."); }
 use iControlTypeCast;
  Validate Arguments
 my $sHost = $ARGV[0];
 my $sPort = $ARGV[1];
 my $sUID = $ARGV[2];
 my $sPWD = $ARGV[3];
 my $sProtocol = "https";
 if ( ("80" eq $sPort) or ("8080" eq $sPort) )
     $sProtocol = "http";
 if ( ($sHost eq "") or ($sPort eq "") or ($sUID eq "") or ($sPWD eq "") )
     die ("Usage: ConfigSyncStatus.pl host port uid pwd\n");
  Transport Information
 sub SOAP::Transport::HTTP::Client::get_basic_credentials
     return "$sUID" => "$sPWD";
 $DBVariable = SOAP::Lite
     -> uri('urn:iControl:Management/DBVariable')
     -> proxy("$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi");
 eval { $DBVariable->transport->http_request->header
     'Authorization' =>
         'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '')
 &getConfigSyncStatus();
  getDBVariable
 sub getDBVariable()
     (@dbKeys) = @_;
     $soapResponse = $DBVariable->query
             SOAP::Data->name(variables => [@dbKeys])
     &checkResponse($soapResponse);
     @VariableNameValueList = @{$soapResponse->result};
     my @ValueArray;
     foreach $VariableNameValue (@VariableNameValueList)
         $name = $VariableNameValue->{"name"};
         $value = $VariableNameValue->{"value"};
         push @ValueArray, $value;
     return @ValueArray;
  getConfigSyncStatus
 sub getConfigSyncStatus()
     @dbKeys = (
         "configsync.autodetect",
         "configsync.localconfigtime",
         "configsync.peerconfigtime",
         "configsync.localsyncedtime",
         "configsync.state");
     (@dbValues) = &getDBVariable(@dbKeys);
     print "CONFIG SYNC STATUS --\n";
     if ( "disable" eq @dbValues[0] )
         Standalone
         print "    Status:  disabled\n";
         print "    Last change (Self):  ", &getLocalTime(@dbValues[1]), "\n";
     else
         HA Pair
         print "    Status:  @dbValues[4]\n";
         print "    Last change (Peer):  ", &getLocalTime(@dbValues[2]), "\n";
         print "    Last Configsync:  @dbValues[3]\n";
  getLocalTime
 sub getLocalTime()
     ($timeNumber) = (@_);
     ($sec,$min,$hour,$mday,$mon,$year,$wday,$yday,$isdst) =
                                                 localtime($timeNumber);
     $timeString = sprintf("%04d-%02d-%02d %02d:%02d:%02d", $year+1900, $mon, $mday, $hour, $min, $sec);
     return $timeString;
  checkResponse
 sub checkResponse()
     my ($soapResponse) = (@_);
     if ( $soapResponse->fault )
         print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n";
         exit();
-Joe
Glad to help. And thanks for the corrections…
-Joe
Hmm…
I’ve tried runnning this… Apart from perl suggesting that @dbValues[xx] would be better written as $dbvalues[xx] my F5’s always return a 0 for autodetect… What exactly is this supposed to represent in the db? Because mine all have configsync autodetection between the pairs when you view the web GUI configsync settings…
TIA
Hamish
