Hi experts, I need help to deploy some configuration in multiple big-ip. For example, I already create some pool and I want to deploy in some big-ip is like big-ip1, big-ip2, and big-ip3 at the same time. But in the device box, it cant add multiple devices is only one. Thank you everyone.
Best Regards.
If I’m understanding your question correctly, you have some configuration objects on one BIG-IP system that you would like to replicate (copy) to other BIG-IP systems, but none of the systems are in a device group where you could use ConfigSync to do this. If so, then SCF will be your best friend. You can create an SCF backup of the configuration on “BIG-IP1,” edit the SCF text file output to include only those configuration objects (such as pools or virtual servers) you wish to copy to the other systems, then do a tmsh load sys config merge file… to merge the configuration objects from the edited SCF into the existing configuration on BIG-IP2, BIG-IP3, and more. See K81271448: Merging BIG-IP configuration objects into the running configuration using tmsh for more information on how to do this.
