Dear all!
I don’t know how to deployment LTM in 1 VLAN. Because I don’t like using topology with internal and external vlan. Do anybody have configure guide for 1 vlan ? Please send it for me
Thanks!
Dear all!
Thanks!
Hi vhv84,
There are instructions on ask.f5.com. Here is a specific link regarding One arm topology. Keep in mind that one arm topology is not usually favored because you loose the real address of the client IP, unless you do not care for that.
I hope this helps
Bhattman
