How to deploy an F5XC SMSv2 site with the help of automation
To deploy an F5XC Customer Edge (CE) in SMSv2 mode with the help of automation, it is necessary to follow the three main steps below:
  1. Verify the prerequisites at the technical architecture level for the environment in which the CE will be deployed (public cloud or datacenter/private cloud)
  2. Create the necessary objects at the F5XC platform level
  3. Deploy the CE instance in the target environment
We will provide more details for all the steps as well as the simplest Terraform skeleton code to deploy an F5XC CE in the main cloud environments (AWS, GCP and Azure).
Step 1: verification of architecture prerequisites
To be deployed, a CE must have an interface (which is and will always be its default interface) that has Internet access. This access is necessary to perform the installation steps and provide the “control plane” part to the CE. The name of this interface will be referred to as « Site Local Outside or SLO ».
This Internet access can be provided in several ways:
“Cloud provider” type site:
  • Public IP address directly on the interface
  • Private IP address on the interface and use of a NAT Gateway as default route
  • Private IP address on the interface and use of a security appliance (firewall type, for example) as default route
  • Private IP address on the interface and use of an explicit proxy
Datacenter or “private cloud” type site:
  • Private IP address on the interface and use of a security appliance (firewall type, for example) or router as default route
  • Furthermore, public IP addresses on the interface and “direct” routing to Internet
It is highly recommended (not to say required) to add at least a second interface during the site first deployment. Because depending on the infrastructure (for example, GCP) it is not possible to add network interfaces after the creation of the VM. Even on platforms where adding a network interface is possible, a reboot of the F5XC CE is needed. An F5XC SMSv2 CE can have up to eight interfaces overall.
Additional interfaces are (most of the time) used as “Site Local Inside or SLI” interfaces or “Segment interfaces” (that specific part will be covered in another article).
Basic CE matrix flow.
InterfaceDirection and protocolsUse case / purpose
SLOEgress – TCP 53 (DNS), TCP 443 (HTTPS), UDP 53 (DNS), UDP 123 (NTP), UDP 4500 (IPSEC)Registration, software download and upgrade, VPN tunnels towards F5XC infrastructure for control plane
SLOIngress – NoneRE / CE use case
CE to CE use case by using F5 ADN
SLOIngress – UDP 4500Site Mesh Group for direct CE to CE secure connectivity over SLO interface (no usage of F5 ADN)
SLOIngress – TCP 80 (HTTP), TCP 443 (HTTPS)HTTP/HTTPS LoadBalancer on the CE for WAAP use cases
SLIEgress – Depends on the use case / application, but if the security constraint permits it, no restriction
SLIIngress – Depends on the use case / application, but if the security constraint permits it, no restriction
For advanced details regarding IPs and domains used for:
  • Registration / software upgrade
  • Tunnels establishment towards F5XC infrastructure
Please refer to: F5 Distributed Cloud Services IP Address and Domain Reference for Firewall or Proxy Settings | F5 Distributed Cloud Technical Knowledge
Step 2: creation of necessary objects at the F5XC platform level
This step will be performed by the Terraform script by:
  • Creating an SMSv2 token
  • Creating an F5XC site of SMSv2 type
API certificate and terraform variables
First, it is necessary to create an API certificate. Please follow the instructions in our official documentation here: Credentials | F5 Distributed Cloud Technical Knowledge
or here: Credentials | F5 Distributed Cloud Technical Knowledge
Depending on the type of API certificate you want to create and use (user credential or service credential).
In the Terraform variables, those are the ones that you need to modify:
The “location of the api key” should be the full path where your API P12 file is stored.
variable "f5xc_api_p12_file" {
  type        = string
  description = "F5XC tenant api key"
  default     = "<location of the api key>"
If your F5XC console URL is https://mycompany.console.ves.volterra.io then the value for the f5xc_api_url will be F5 Distributed Cloud Console
variable "f5xc_api_url" {
  type    = string
  default = "https://<tenant name>.console.ves.volterra.io/api"
When using terraform, you will also need to export the P12 certificate password as an environment variable.
export VES_P12_PASSWORD=<password of P12 cert>
Creation of the SMSv2 token.
This is achieved with the following Terraform code and with the “type = 1” parameter.
#F5XC objects creation
resource "volterra_token" "smsv2-token" {
  depends_on = [volterra_securemesh_site_v2.site]
  name       = "${var.f5xc-ce-site-name}-token"
  namespace  = "system"
  type       = 1
  site_name  = volterra_securemesh_site_v2.site.name
Creation of the F5XC SMSv2 site.
This is achieved with the following Terraform code (example for GCP). This is where you need to configure all the options you want to be applied at site creation.
resource "volterra_securemesh_site_v2" "site" {
  name                    = format("%s-%s", var.f5xc-ce-site-name, random_id.suffix.hex)
  block_all_services      = false
  logs_streaming_disabled = true
  enable_ha               = false
  labels = {
    "ves.io/provider" = "ves-io-GCP"
  re_select {
    geo_proximity = true
  gcp {
    not_managed {}
For instance, if you want to use a corporate proxy and have the CE tunnels passing through the proxy, the following should be added:
custom_proxy {
      enable_re_tunnel = true
      proxy_ip_address = "10.154.32.254"
      proxy_port = 8080
And if you want to force CE to REs connectivity with SSL, the following should be added:
tunnel_type = "SITE_TO_SITE_TUNNEL_SSL"
Step 3: creation of the CE instance in the target environment
  • Generating a cloud-init file
  • Creating the F5XC site instance in the environment based on the marketplace images or the available F5XC images
How to list F5XC available images in Azure:
az vm image list --all --publisher f5-networks --offer f5xc_customer_edge --sku f5xccebyol --output table | sort -k4 -V
And check in the output, the one with the highest version.
x64             f5xc_customer_edge  f5-networks  f5xccebyol    f5-networks:f5xc_customer_edge:f5xccebyol:9.2025.17    9.2025.17
x64             f5xc_customer_edge  f5-networks  f5xccebyol    f5-networks:f5xc_customer_edge:f5xccebyol:2024.40.1    2024.40.1
x64             f5xc_customer_edge  f5-networks  f5xccebyol    f5-networks:f5xc_customer_edge:f5xccebyol:2024.40.2    2024.40.2
x64             f5xc_customer_edge  f5-networks  f5xccebyol    f5-networks:f5xc_customer_edge:f5xccebyol:2024.44.1    2024.44.1
x64             f5xc_customer_edge  f5-networks  f5xccebyol_2  f5-networks:f5xc_customer_edge:f5xccebyol_2:2024.44.2  2024.44.2
Architecture    Offer               Publisher    Sku           Urn                                                    Version
We are going to re-use some of the parameters in the Terraform script, to instruct the Terraform code which image it should use.
source_image_reference {
    publisher = "f5-networks"
    offer     = "f5xc_customer_edge"
    sku       = "f5xccebyol"
    version   = "9.2025.17"
Also, for Azure, it’s needed to accept the legal terms of the F5XC CE image. This needs to be performed only once by running the following commands:
Select the Azure subscription in which you are planning to deploy the F5XC CE:
az account set -s <subscription-id>
Accept the terms and conditions for the F5XC CE for this subscription:
az vm image terms accept --publisher f5-networks --offer f5xc_customer_edge --plan f5xccebyol
How to list F5XC available images in GCP:
gcloud compute images list --project=f5-7626-networks-public --filter="name~'f5xc-ce'" --sort-by=~creationTimestamp --format="table(name,creationTimestamp)"
NAME                                               CREATION_TIMESTAMP
f5xc-ce-crt-20250701-0123                          2025-07-09T02:15:08.352-07:00
f5xc-cecrt-20250701-0099-9                         2025-07-02T01:32:40.154-07:00
f5xc-ce-202505151709081                            2025-06-25T22:31:23.295-07:00
How to list F5XC available images in AWS:
aws ec2 describe-images \
  --region eu-west-3 \
  --filters "Name=name,Values=*f5xc-ce*" \
  --query "reverse(sort_by(Images, &CreationDate))[*].{ImageId:ImageId,Name:Name,CreationDate:CreationDate}" \
  --output table
And check in the output, the ami with the latest creation date.
Also, for AWS, it’s needed to accept the legal terms of the F5XC CE image. This needs to be performed only once.
Go to this page in your AWS Console
Then select “View purchase options” and then select “Subscribe”.
Putting everything together:
Global overview
We are going to use Azure as the target environment to deploy the F5XC CE.
The CE will be deployed with two NICs, the SLO being in a public subnet and a public IP will be attached to the NIC.
We assume that all the prerequisites from step 1 are met.
Terraform skeleton for Azure is available here: GitHub - veysph/Prod-TF · GitHub
It’s not intended to be the perfect thing, just an example of the minimum basic things to deploy an F5XC SMSv2 CE with automation. Changes and enhancements based on the different needs you might have are more than welcome. It’s really intended to be flexible and not too strict.
Structure of the terraform directory:
  • provider.tf contains everything that is related to the needed providers
  • variables.tf contains all the variables used in the terraform files
  • f5xc_sites.tf contains everything that is related to the F5XC objects creation
  • main.tf contains everything to start the F5XC CE in the target environment
Deployment
Make all the relevant changes in variables.tf.
Don’t forget to export your P12 password as an environment variable (see Step 2, API certificate and terraform variables)!
Then run,
terraform init
terraform plan
terraform apply
Should everything be correct at each step, you should get a CE object in the F5XC console, under
Multi-Cloud Network Connect --> Manage --> Site Management --> Secure Mesh Sites v2
Thanks so much for that detailed steps to deploy SMSv2.
