How To Delete An irule using Rest API with CURL
Hello,
I am a bit stumped. I know I can add an irule using the rest api running the following command:
curl -sku ':' -H "Content-Type: application/json" -X PATCH https://bigip1/mgmt/tm/ltm/virtual/virtual-server -d '{"rules": ["/Common/cool-irule"] }'
but for the life of me I can not figure out the payload to remove an irule. I am 2 hours into testing and research and I am stumped. Any ideas would be appreciated.
Hi, You can do that using python sdk:
import requests
from f5.bigip import ManagementRoot
requests.packages.urllib3.disable_warnings()
connect to your F5
b = ManagementRoot('your_f5_mgmt_ip', 'user', 'pass')
load the rule
rule1 = b.tm.ltm.rules.rule.load(name='irule_delete', partition='Common')
Delete the Rule
rule1.delete()
Regards,
Hygor
This works for 12.1.0
curl -ku 'user:pass' -X DELETE https://bigip1/mgmt/tm/ltm/rule/cool-irule
Hygor,
Thank you for the response. We are trying to keep these as API calls back to the F5. Also, the proposed solution would work to delete an irule but it would not work to remove an assigned irule from a VIP.
Regards,
Javier
Ok, you want to remove the irule from the virtual server. Here is how you can do that:
import requests
connect to your F5
load the virtual server
vip = b.tm.ltm.virtuals.virtual.load(name='vs_name')
list irules in vs
vip.rules
[u'/Common/irule1', u'/Common/irule2']
In this case we'll remove the irule2. The irule1 will remain in the virtual server
vip.rules = ['/Common/irule1']
update the configuration
vip.update()
Hope that it helps you. Regards,
Hygor
Hygor,
Thank you very much for the response!
Regards,
Javier
