How to create Policy rul to match HTTP::URI path contains
Policy HTTP URI match
To clarify, are you asking about creating an iRule or about creating an LTM policy, which should be based on a specific uri?
Local Traffic > Policies > Create
Give it a name, click create.
Then add a Rule to it, which has HTTP URI selected in the first drop down box, path selected in the second box, and contains in the third box.
You can select what happens when your criteria are met in the field below that.
Hope that helps! If it does please up-vote and select this answer, it’d be greatly appreciated!
-Dylan
Sorry, but it was not my intention to submit this question without context. My goal is to check the URI to see if it contains “logout”, but does NOT include “service”. This would make it a default Service Logout if NO specific logout service is specified. I have a working iRule (included below) and I tried to recreate it with a Traffic policy. The policy causes a “Too many redirects” error. It seems like I am misunderstanding the logic or the parameters used in the policy conditions, but I cannot figure out how.
Here are the details: Below I included my existing iRule, which seems to work fine. when I visit "; it does a single redirect to my desired logout endpoint
when HTTP_REQUEST { if { ( [HTTP::uri] contains “logout” ) and !( [HTTP::uri] contains “service” ) } { HTTP::redirect "https://mycasserver.com/cas/logout?service=https://federatedhost.com/common/wsfederation?wa=wsignout1.0"; }
I reviewed the policy manual here: Introducing Local Traffic Policies
I created a policy and when I trace the headers it keeps redirecting repeatedly until the redirect threshold is reached and error ensues. Below is my policy:
