How to create new Monitors and Pools in Java iControl library?
I’m using the iControl Java library and am trying to create a new Monitor and Pool. Can anyone tell me: 1. What Java classes I should be using (and perhaps what methods I should be looking at)? 2. Perhpas show me some sample or pseudo-code for doing this? 3. At the very least, tell me what iControl API endpoints I should be hitting? If no one is familiar with the Java library, I might be able to figure out what Java code to call based on the API endpoints that need to be invoked.
Thanks in advance!
you have a Java example here to enable/disable pool members : https://devcentral.f5.com/wiki/iControl.JavaPoolMemberControl.ashx
and here some deep dive with an example to create a pool: https://devcentral.f5.com/articles/java-icontrol-objects-ltm-pool
