Can someone help me by providing sample code of how I can create a regular user on BIG-IP (11.5) using iControl and Powershell?
Try this. It works for me in 11.5.0. Understanding the API a little bit comes from here.
region Check that SnapIn is installed
try {
Add-PSSnapIn -Name iControlSnapIn -ErrorAction Stop;
} catch {
Write-Host " iControlSnapin is not installed." -ForegroundColor Red;
Write-Host " Download the snapin from https://devcentral.f5.com/d/microsoft-powershell-with-icontrol" -ForegroundColor Red;
Exit the script
return;
endregion
region Credentials
if ($f5Credentials -eq $null) {
$f5Credentials = $(Get-Credential -Message "Credentials for F5 server connection");
Write-Verbose " Credentials: $($f5Credentials.Username)";
endregion
region Create the User
Establish the connection to the BIG-IP server
$iConn = Initialize-F5.iControl -HostName "SERVER" -Username $f5Credentials.Username -Password $f5Credentials.GetNetworkCredential().Password;
if (!$iConn) { throw "Connection could not be established to $($connSrc.Server)."; return; }
Get the iControl object
$iCtrl = Get-F5.iControl;
Create the UserInfo3 object
$userInfo = New-Object iControl.ManagementUserManagementUserInfo3;
User
$userInfo.User = New-Object iControl.ManagementUserManagementUserID;
$userInfo.User.name = "USERNAME";
$userInfo.User.full_name = "NAME";
Password
$userInfo.Password = New-Object iControl.ManagementUserManagementPasswordInfo;
$userInfo.Password.is_encrypted = $false;
$userInfo.Password.password = "PASSWORD";
Permissions
$perms = New-Object iControl.ManagementUserManagementUserPermission;
$perms.partition = "[All]"; Or name of single partition
$userInfo.Permissions = $perms;
Login Shell
$userInfo.login_shell = "/bin/bash"; Bash: "/bin/bash" || TMSH only: "/bin/false";
Execute the create function
$iCtrl.ManagementUserManagement.create_user_3($userinfo)
endregion
ah!
You use iControl even though you specify $iCtrl = Get-F5.iControl;
I was using $iCtrl to specify the objects defined later on in the script
