How to create f5 loadbalancer instance using java?
Hi Team,
I’m new to f5 load balancer. One of my client have the F5 load balancers. Now I need to implement java program to create the instances of load balancers and I need to add the servers to that load balancer. Hence I need java api to work with f5 load balancer to create and add servers. And where can I find the documentation for java f5 load balancer api.Can you please guide me on this.
I’ve not heard of an API specifically for Java.
However, if you’re able to do a HTTP request from that API, then you can simply use the rest API.
Here’s the devCentral wiki for the API
https://devcentral.f5.com/Wiki/Default.aspx?Page=HomePage&NS=iControlREST
HTH.
Hello, Please see if the earlier F5 answers link could help, which shows to use Java (SOAP) iControl API automation- REST / Python BigSuds /Java lib - which one is best
