Hi !
I implement a SAML2.0 Service Provider using HTTP Post binding with APM.
For an integration with an IDP, I need to control fields in The SAMLRequest created by APM.
The IDP supports multiple authentication mechanisms, and i need to control which one to use. The standard mechanism to do this is to set a value in a AuthContext (I suspect they relly mean a RequestedAuthnContext) element in the SAMLResponse.
Unfortunately, I cannot find a way to control the content of the SAMLResponse with APM. Is there a way? If not, how could I go about signaling to the IDP what authentication I want the User to use?
