Can someone help to write the exact command to login to the vpn server thought command prompt in windows. I tried with the following command but it is just launching the BIG EDGE IP client, but it is not logged in.
f5fpc -start /h https://vpnxxx.server.com /u my_userid /p my_password
-Vinoth
Worked for me. Just needed to ensure that the edge client wasn’t running first.
in a batch file you could do the following:
@echo off
taskkill /im f5fpc.exe /f
No reason why that wouldn’t work. It would kill all instances of the f5fpc process then start the VPN for you/
