How to configure tomcat when using APM as a SAML service provider?
Hello,
Can anyone provide doc’s or insight on how to configure tomcat when using APM as a SAML service provider?
I found the below F5 doc’s for setting up F5 APM as a SAM service provider, but anyone have any insight on how to configure the backend tomcat server ?
Thank you for any and all help!
Does tomcat requires/prompts any authentication when accessed directly? If not after successful authentication thru IdP, the resource can be accessed.
as asked above, what exactly does Tomcat require exactly? in principle there is nothing to configure if you can just access it.
