I tried configuring Port Remap on an existing application topology but I still see in the traffic logs in L2 Security Services with Destination Port 443, is this a limitation on Existing Application topology as I’ve read some documents that states that in order to configure Port Remap we need to add http profile in interception rules which aren’t available to configure in existing application topology.
I hope you’ve already found the answer to this. You’re right—Port Remap doesn’t work in the existing application topology because it lacks L7 profile support in interception rules. If you need Port Remap, you’ll have to use a different topology that allows L7 profiles in interception rules.
Reference :
