SP
October 31, 2019, 4:20pm
1
i have been searching for how to configure “PEM GY interface” .i configured below in “profile of subscriber management”
pem profile diameter-endpoint Gy_endpoint {
defaults-from diameter-endpoint
destination-host none
destination-realm OCS
fatal-grace-time {
time 500
msg-max-retransmits 2
msg-retransmit-delay 1500
origin-host gy.bigip.f5.com
origin-realm bigip.f5.com
product-name BIG-IP
supported-apps { Gy }
is the configuration correct? any other configuration required for " PEM GY interface"?Any suggestions are greatly appreciated.
what i see look pretty similar to the documentation:
https://devcentral.f5.com/s/question/0D51T00006zuvHdSAI/how-to-configure-pem-gy-interface
i assume something is not working or are you just double checking?
SP
November 12, 2019, 6:34am
3
I want to know about Configuration needed for PEM GY configuration.The above commands i got in a document,not sure what are configuration needed for PEM GY to work .It will be great if you can help me
got no direct experience, might be wise to reach out to your local F5 team and see if a partner with experience in this can assist.
