I have F5 BIGIP VE 12.1.2
I am trying to use 192.168.60.2 as my management IP
If i configure 192.168.10.X a/ my management IP i can ping both the 192.168.70.0/24 and 192.168.60.0/24
However if i configure 192.168.60.X as my management ip I cannot ping anything but 192.168.60.X
Same goes for for the 192.168.70.X network
If i try to create a net route i get an error (why cause google told me to)
create net route 192.168.10.0/24 gw 192.168.10.1
Static route gateway 192.168.10.1 is not directly connected via an interface
Just for fun I set my management IP to 192.168.10.47 and ran the same command and got the same error
I have two nics eth0 and eth1
cat /etc/ethmap
eth0 11.22.33.44.55.66
eth1 22.55.88.44.55.66
The reason I have to use 192.168.60.X as my management IP is my webserver are on 192.168.10 and i cannot change them
How do i configure the f5 so I can talk to both the 192.168.10.0/24 and 192.168.60.0/24 networks
