I have servers located in 2 different data centers, same architecture.
Web servers are sending request to an LB where there are MySQL server behind it.
I want to configure those LB to be in Active/Active mode so they are splitting the traffic between them, and if 1 fails, the other take both loads.
Right now LB in location A only take traffic from Web server at location A. Same for B.
So my new architecture would be that both LB will share the load from A and B.
So far, I configured both Big-IP with the self IP and the same floating IP. I’d like to know if this configuration will be enough, do I have to configure the Network Failover ?
If yes, how do I configure it ? The management address will have to be the same as the management port ?
If I’m reading your post correct, then that’s not how Active/Active works…
Active/Active denotes the fact that both units can serve virtual servers simultaneously… Not both serving the same VS and IP address at the same time… To configure it, simply place into active/active config (A checkbox under the HA options) and then assign individual VS’s to either unit 1 or unit 2. The VS will then ‘live’ on the unit specified. If one of the units goes down, the other uni will takeover BOTH units load.
So you’d have 2x VS’s. One for MySQL A, one for MySQL B. MySQL A VS would be on unit 1, MySQL B VS would be on unit 2. Then simply configure web A to use MySQL A VS and web B to use MySQL B VS.
When an LTM takes over a unit, it takes over all the VS’s for that unit. When an LTM takes over a VS, it responds for the IP address associated with it.
This assumes you have a network spanned over the two DC’s of course… WHich I’m assuming is correct…
